No Juice to Coil
Old 04-23-05, 04:14 AM
shockman
Post No Juice to Coil
Hello folks, awhile ago I had a little mishap with my whirlpool electric range where some type of interaction between the hot coil, aluminum pot, and the water inside caused a minor explosion (more of a spark/pop) and that coil, and only that coil, has had no power since. I purchased a new heating coil, but still no power, should I replace the coil connector that runs to the board behind the unit???
Much Appreciation
Shockman
Old 04-23-05, 11:14 AM
scoash
Inspect the element recepticle for damage. If ok there may have been damage to the burner switch. You can probably switch it with another one in the console to see if it'll work.
