Maytag Dryer - No Heat
Old 04-25-05, 05:07 PM
A
Received 1 Upvote on 1 Post
Maytag Dryer - Dependable Care - Model LDE9304ACE with no heat.
I have checked the Heating Element, High Limit Thermostat, Heater Thermal Fuse, and Thermal Fuse for Motor Run, and all have continuity.
The Cycling Thermostat (4-pole) has continuity across the outside terminals (red and purple wires), and continuity across the inside terminals (gray and black).
Dryer vent hose is <2 feet in length, and is clear. Circulator "squirrel cage" is in great shape, and spins freely, no clogs or missing/damaged vanes. Very good air flow (altho all cold) out of duct pipe.
Circuit breaker has never tripped. Problem started after one load of normal drying. On second load, there was some "popping and crackling" and an extended drying cycle............actually never dried the clothes.
Dryer runs, but blows cold air. What do I check next, and how?
Thanks for any help,
Old 04-26-05, 12:43 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: Rick
If there is continuity it does not mean the heating element is glowing. Run the machine an visually check the element. If the element(s) do not glow in one cycle, try another and verify operation. Try another cycle. Problem may be with the timer and or one specific setting cycle.
Since the codes are turned off in this forum topic, copy and repaste (the links below) into the browsera address bar.
http://forum.doityourself.com/showthread.php?postid=555421#post555421
http://forum.doityourself.com/showthread.php?threadid=164145
Electric Dryer Prior Posts Help:
http://forum.doityourself.com/showthread.php?t=159497
DIY Help Links:
http://links.doityourself.com/
http://links.doityourself.com/links/appliances/
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Advertisers & Sponsors Pages:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
Maytag Appliance Help Forum Thread:
http://forum.doityourself.com/showthread.php?t=153846
Helping Out Here Too.
Web Site Host, Forums Monitor & Multiple Topics Moderator.
Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 04-26-05, 01:13 PM
bambiblaster's Avatar
CHECK YOUR WIRE DIAGRAM AND SEE IF VOLTAGE IS GOING TO ELEMENT FROM THE TIMER.. IF NONE ITS THE TIMER
Old 04-26-05, 02:20 PM
A
Problem resolved
Dryer had only 110V at plug, which will run blower, timer, turn the drum, etc. Everything EXCEPT heat up the heating element.
Problem was in a faulty circuit breaker that one side had tripped and would not re-set. Replaced circuit breaker, and everything is fine.
