GE Washer : Air Bell Coupling
Old 05-04-05, 11:21 AM
daveparrott
Was wondering if anyone knows how to remove the air bell
coupling on a newer model GE washer. There was a nice schematic
in the washers control panel it states to remove a 7/16 bolt that
holds the air bell coupling to the transmission spline shaft. No problems
but now I can't figure how to remove the air bell coupling have tried
pulling, turning and lightly prying nothing helps. Any help on this would
be appreciated.
Old 05-04-05, 04:11 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
THERE IS A TOOL .. I USE A REGULAR OLD WHEEL PULLER ... PRAY SOME ANTI-SEIZE INTO HOLE ND LET IT SOAK THN USE THE PULLER SLOWLY... I ALSO PUT THE BOLT IN HALF WAY SO PULLER HAS SOMETHING TO PUSH AGAINST..
