Built in oven does not heat up
Old 05-04-05, 05:27 PM
laxmi
Question Built in oven does not heat up
Hi,
I have a whirlpool built in oven. Suddenly it stopped heating up.
The timer, clock , light and all the buttons are working properly
except for the coils do not get heated up. Is this some fuse issue?
Could some one please let me know what I can check for.
Thanks,
Laxmi
Old 05-04-05, 08:45 PM
ampz's Avatar
Is the unit plugged into a receptacle or does the wire go right into the back?You should 1st check that you are getting 230 volts.If you are at all uncertain about working with electricity do not attempt this call a pro.
