Whirlpool Dryer won't stop running
Old 05-10-05, 07:58 AM
G
Our dryer has started acting up. The first symptom was that it would start running immediately after setting the timer, before even pushing the "Push to start" button. Now it keeps tumbling even with the timer switch in the off position. The only way to get it to stop is to open the door. My best guess is that it is the timer switch that has failed. Is this likely to be true?
Old 05-11-05, 06:16 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
WHEN YOU FIRST HAD A PROBLEM IT WOULD BE THE PUSH TO START BUTTON... THIS WILL PROBABLY SOLVE BOTH PROBLEMS...
