Admiral washing machine water leak
Old 05-11-05, 02:41 PM
Jo-Ann
I have an Admiral LNC6757A71 washing machine. There is no problem with water coming into the machine, but when it is time to drain, the water's draining on my floor. I cannot figure out how to open the machine. Do I have to remove everything from the dial panel downward? A local parts store told me that there were two screws on the bottom of the front panel and that all I had to do was to remove those.
There are no screws on the front bottom of the machine and I've lost a little confidence in this person. Does anyone know how to gain access to find out what's leaking? Thanks.
Jo-Ann
Old 05-11-05, 07:38 PM
bambiblaster's Avatar
Received 1 Vote on 1 Post
JO-ANN
ON YOUR MODEL TAKE A PUTTY KNIFE AND FROM LEFT AND RIGHT CORNERS SLIDE IT ACROSS ABOUT 2 INCHES TO A CLIP PUSH IN ON THESE CLIPS AND RAISE TOP SAME TIME... YOU WILL THE SEE 2 SCREWS... REMOVE THEM AND THE FRONT WILL COME OFF... OLDER MODELS HAD 2 SCREWS AT THE BOTTOM...
