Need help quick! (Washing Machine Leak)
Old 05-13-05, 06:29 PM
e52
Unhappy Need help quick! (Washing Machine Leak)
My wife notified me that there was a leak from under our washer, but she only said it did it a few times. Well it's happening more frequently and with greater amounts of water. I originally thought it was coming from the washer, but I found where the water is coming from. It's not coming from the washer at all. Where the drain hose leads out of the washer and in to the outlet at the wall is where I observed water coming out. The drain water is backing up and coming out the drain. What is causing this and how can I fix it quickly before it ruins my floor and wall. Any help is appreciated.
Thanks,
E52
Old 05-14-05, 12:14 AM
scoash
Your drain standpipe is plugged. Try a snake or call a plumber.
Old 05-14-05, 07:19 PM
e52
Sounds simple enough. Thanks for the help.
