Whirlpool Washer Won't Spin
Old 05-19-05, 09:13 AM
walterannz
I bought the washer about 3 years backs.
--wash cycle works
--it drains
--WON'T SPIN.
I have checked the coupler, it is fine.
When I close the lid I can hear the motor, but the tub does not spin.
Please Help..........................
Old 05-19-05, 09:18 AM
T
washing won't spin
its probably the belt. it just happened to my fridgidaire. i bought the belt from a household parts store and put it on in 30 minutes. might take longer with yours, mine had a spring attached to one of the rollers so it made it easier. still took 30 minutes though ha ha. don't have a repairman do it if you can do it yourself. you'll kick yourself after he puts it on so easy. good luck
t.
walterannz
WHIRLPOOL WASHER WON't SPIN
I have read about the lid switch....
How do I tell its the lid switch that is not working?
I hear the motor when I close the lid, but the tub does not spin
Old 05-19-05, 01:14 PM
walterannz
Where is the belt located? I opened it, did not see a belt....
Old 05-19-05, 01:17 PM
walterannz
I guess my washer is direct drive
Old 05-19-05, 05:14 PM
bambiblaster's Avatar
Received 1 Vote on 1 Post
You Can Skip The Lid Switch Because The Water Drained.. And You Watched It Agitate Right... Remove The Agitator And Check The Drive Block.. May Be Stripped...
