cracked washer tub
Old 05-25-05, 07:01 PM
berryfine
cracked washer tub
my husband and I just finished taking the bottom off of our ge profile washer to investigate a leak, hoping to only find a faulty or loose hose, we discovered that the outer tub has a 3 inch crack. Can this be fixed at least temporarly?
Old 05-25-05, 09:17 PM
marknflorida
cracked tub
If this is a newer model with the plastic tub, then the tub is pretty much shot. I have used, in the past, some clear silicone and have had some success with that on smaller holes. If the crack is near the bottom or on the bottom of the tub then your chances are slim. You can try the silicone, but you have to silicone inside and outside the tub and let it cure for at least a day. If it still leaks, get another washer, preferably something like a whirlpool, stay away from G.E. products.
Old 05-28-05, 04:53 AM
bambiblaster's Avatar
Received 1 Vote on 1 Post
goto your local appliance parts place and ask if they have a slap stick... its a strip of plastic you can stick over the crack... instructions are on the box... it about 24 inches long and 2 inches wide....
Old 05-29-05, 07:20 PM
Also Depending On Age May Still Be Under Warranty... Check Owners Manual...
