How to Build a Refer/freezer
Old 07-12-05, 08:51 AM
chaywood
Unhappy How to Build a Refer/freezer
I want to build a large 12x12 freezer and a 12x12 refrigerator for my deer processing. How can I do this?
Old 07-12-05, 11:35 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
You could likely put together the box but this is a small part of having a commercial cooler/freezer. Installing the cooling equipment will need to be farmed out.
This part is not a diy endevour.
I would suggest you take the measurements and use you will make of the cooler and freezer to a refrigeration contractor for a price.
You will find the walk-in freezer to be quite a bit more expensive that a cooler and may want to use other methods for freezing.
