Kenmore Dryer 70 Series won't start
I have a Kenmore Dryer 70 Series. model 110.96573220. The problem is the dryer will not start when I press the start button. The timer works but nothing else does. I'm assumming the safety switch on the door works because it will stop the timer when the door is opened and the timer will start again when the door is closed.
Any ideas of where I should start? Thanks
Turn Off Breaker And Turn Back On... Check To See If You Have 220 Volts To Machine Left To Center 120 / Right To Center 120 / Right And Left 220v... If So Unplug Remove Rear Panel And Lower Center There Is A White 2 Inch Thermal Fuse That Could Be Blown...
