Kenmore Elite Oven Door Locked
I have a Kenmore Elite Duel Fuel Range (Model No. 790.75503) and I started the Self Clean mode, but then opened the door before the latch locked and then closed it and the door locked. So basically I interupted the cleaning process right before the door lock. The range is supposed to just say LOCKED then on the little screen and it just said "door" and beeped - even though the door was locked. I tried canceling and starting it over, but I get the same results. And now it's still locked.
Is there any reseting it or unlocking it without getting someone out here.
Thanks
T
Thanks
T
Kenmore
Not real familiar with that particular model so here's just a suggestion. Try turning the power off to the stove by circuit breaker or pull the plug & try to open door. It also may be possible you bent something on the door latch by trying to lock while in cleaning mode. If thats the case its time to call the service man. Dave
