Whirlpool Won't Final Spin
Old 08-17-05, 08:14 PM
FrankieB
Question Whirlpool Won't Final Spin
I have a Whirlpool CAP2761EW0 commercial washer. It will step through all the cycles (fill, agitate, spin & drain, fill, drain). However, the water will drain out but it won't initiate the final spin. The wash cycle spin is fine. The rinse cycle spin just doesn't happen. Any thoughts? I haven't checked the lid switch, yet.
Thanks.
Old 08-24-05, 10:49 AM
Sue G
I had a similar problem with my washer recently. It may be a clog in your hoses or in the pump itself. I would try to check for clogs first, then I would check the pump. The repair man that came out said that the spin cycle won't work if there is too much water in the drum. Draining the water first may help too. Good Luck.
Old 08-30-05, 05:06 PM
FrankieB
The problem was the transmission and was replaced.
Thank you for all the incredibly helpful responses.
