GE WVSR1060A1WW washer won't agitate but spins.
Old 10-12-05, 09:36 AM
jcrawshaw's Avatar
Approx 5 yrs old. Will fill then the motor comes on and spins the belt, that agitator moves a fraction of a turn, then stops and the motor and belt continue to spin. After the wash cycle, the machine drains fine and goes into the spin cycle. Any guess as to what I'm looking at for a problem and can I fix it myself?
Thanks in advance.
James Crawshaw
Old 10-12-05, 09:53 AM
Possibly part # 310 on this photo.
http://www.partselect.com/ModelFrame...Machine&Mark=3
or the inside of the agitator where it keys in.
Old 10-12-05, 10:51 AM
jcrawshaw's Avatar
Ok, I'll let it drain and check it out. Will it be easy to tell if that's the problem. Again, thanks alot.
James
Old 10-12-05, 11:25 AM
yes. Can you turn the agitator by hand now. If the piece is broke I think the agitator would turn pretty easy
Old 10-12-05, 11:34 AM
jcrawshaw's Avatar
Hey, thanks so much for your help. It does spin really easy....got it apart and the plastic teeth inside the drive bell are pretty much worn smooth. Calling now to see if I can find one in town or if they can have one for me tomorrow. Again, thanks alot for your help.
James
Old 10-12-05, 11:39 AM
No prob. Glad to help.
Old 07-16-09, 04:07 PM
T
Mine does the same
Mine does the same thing i took it apart as you said! part 310 moves freely in both directions. The teeth on it are fine?????? Any suggestions???
Old 07-16-09, 06:50 PM
D
It turns on the shaft?
bbbbbbbbbbbbbb
Old 07-16-09, 07:03 PM
its hard to tell visually that the splines are trashed. you can feel it easily however
