Kenmore 110 20712990 Help Wont Spin
Kenmore 110 20712990 WASHER Help Wont Spin
My Kenmore (70 Series Wont Spin) Just Makes A Buzzing Sound Can Someone Please Help
Kenmore Washing Machine
Thank You For The Reply. The Washer Filled Up With Water, Then When It Went Intto Rinse It Started To Make A Funny Grinding Noise So I Shut The Machine Off Wants Again Thank You Very Much For Youre Reply . I Know This Isnt Very Much Info But Maybe You Can Get Back To Me And We Can Work This Out. Model #11020712990
Thank You Again John
Sounds Like You Have A Broken Coupler.... Let All The Water Drain Out... The Noise Is Ok... Slide Out An Tip Ack Washer.. On Floor Should Be Pieces Of Rubber And If You Look Between The Trans And Motor Plate You Can See The Coupler....
Speaking of Couplers...
Hey, I just found my coupler under my washer. It looks like it has stripped the teeth off the other part...now what? Can I replace teh white bit with the teeth? Its an Inglis HD washer. I have pictures as well, but wont send them unless you ask. HELP!!!
Thanks,
SH
Thanks,
SH
