Kitchenaid Microwave shut down
Received 0 Votes
Hi, While heating up a cup of coffee the other day, My Kitchenaid microwave combo Model # KEMS306BBL 1, shut off. The contol panal is completely out as well as the light in side the microwave. The oven still works. I replaced the three door microswitches, then I found a large fuse blown.(250V, 20A) and replaced it. The unit powered back up, but when I tried to cook something, it blew the fuse again. Looking for any suggestions................thanks
Bill
Bill
Received 0 Votes
Fuse
There doesn't appear to be any info on the fuse. The original is an Eagle, red in color, the catalog number is difficult to read, but it looks like 666 or 555, difficult to tell the difference between 5's and 6's.
The new one is a Buss non-20amp, green in color.
Received 0 Votes
Microwave - need more ideas
I've replaced both 20A fuses, replaced the door micro-switches, replaced the rectify (attached to the capacitor), had the capacitor and magnotron checked my an electrician which were found to be good. Plugged everything back to gether again, and I blew one of the fuses.
Bill
Bill
If the fuse blows right after you hit the start button, it is probably a shorted high voltage capacitor.
If the fuse blows a few seconds later, it's probably the high voltage transformer.
If neither is bad (and I bet one is) then it calls for more troubleshooting.
Some HV section notes:
The high voltage (HV) transformer itself usually smells or buzzes loudly when it fails, and the fuse may blow a short time after it starts. There may be discoloration on the outside of some of the windings.
The HV capacitor usually shorts when it fails, and that will blow the fuse as soon as you press the start button.
The HV rectifier diode usually shorts when it fails. It can open, too, but there is usually no extra noise when one fails.
I have never seen a magnetron fail by shorting, but I guess it's possible. Most of the time it just quits heating, and may or may not "gurgle" while running.
Received 0 Votes
mw...
Yes I would agree with MW Guy, but also be sure you have the right kind of door switches(amperage & normal open or closed) and that they are wired correctly. I believe if your door switches are correct and you've replaced the main cartridge type fuse for the m/w then more than likely your problem will be the HV Capacitor. Now if you replace the HV capacitor and still having problems I'd say start at square one and retrace everything you've touched to be sure it's correct. Good luck..
Received 0 Votes
More problems
I made the repairs in Nov 2005 and it worked well. I replaced the rectifyer, two microswitches, and a fuse back then.
A few months ago I noticed that it was taking a little longer to cook things (popcorn). A few weeks ago the microwave stopped working. I replaced the magnatron and it made no difference. The fuses work and I checked all of the other major components with a multimeter and they are ok.
The "Touch Module Test" was ok
The "Low Voltage Door Switch Test" was ok.
The "Preprogrammed Test Cycle Test" was ok
The command touch Pad Test:
Clock Set button: Flashing colon OK
Start: S DISPLAYED Nothing
Temp. Reste Button: R Displayed Nothing
Cancel: Time of day OK
Any suggestions?
Bill
Any suggestions?
Bill
