Dryer timer issue
Old 11-19-05, 05:06 AM
Dryer timer issue
Hello,
I have an Estate electric dryer (by Whirlpool), Mdoel #TEDS680EQ2.
Sometimes the timer works and sometimes it doesn't. I can hear it ticking when it is set to timed drying or auto sense drying. When it does work, the dial rotates as it should and turns off the dryer. When it doesn't, it will remain in the same position and doesn't turn off the dryer. Any ideas would be appreciated.
Thank you.
Old 11-20-05, 06:45 AM
Sharp Advice's Avatar
Admin Emeritus
Hello wlsnoops and welcome to the electric appliances forum topic.
The temperature control sensors may be defective. They should be located on the fan blowers housing. There is also a moisture sensor, temperature sensor and a high limit temp sensor. Any one of them could be defective and or inoperative.
Sensors can be checked for electrical continutiy using a ohm meter. As well as the temp selector switch. Be sure the electrical power to the appliance is turned off or the appliance is unpluged from the wall recepticule.
Clean the lint filter and clean and inspect the exhaust ducting. Be sure the hood flapper outside is opening and moving freely. Be sure there is no bends, kinks or restrictions to or in the venting.
Check the hot surface glow element. It should be glowing. If not, first check the control panel. If the heating element is glowing, may not be doing so as hot as it should be. Replace it.
HEATING ELEMENT:
If all the controls are set correctly on the front control panel and the dryer is running and the element fails to glow, the element most likely will need to be replaced.
CONTROL KNOB ADVANCES SLOWLY:
For most dryers this is normal operation when set in the Auto Dry cycle. Once the load begins to dry the timer control will begin to advance. The rate of advancement will begin slowly at first because of the moisture content.
As the load dries, the advancement will advance more quickly. Dryers with moisture sensers will control the timer advancement in cycles where that function is operatable. All normal operations are based upon the cycles selected.
Additional Help and Suggestions:
Read some of the existing posts in this forum. In them will have additional ideas and or suggestions, along with repairs procedures, etc.
Read the manufacturers online web site for additional product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals, which may be available online.
Search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe, which also needs to be downloaded first but worth having once obtained.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and parts dealers are listed in the phone book.
Check back on your question several more times. Other members and moderators posting replies in this forum topic may offer you additional advice, suggestions and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list of current questions automatically.
Helping Out Here Too. Web Site Host, Forums Monitor, Moderator Hiring Agent & Multiple Topics Moderator. Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 11-23-05, 02:10 AM
Thanks for the advice, Sharp Advice. I will check the sensors as you suggest. They are about the only thing I haven't checked.
Sorry it took so long for this follow-up to your quick reply to my question.
