Clothes washer noise
Old 12-12-05, 11:37 AM
R
Repoman75
Bought a new washer for a new house. When the cold water is running into the washer, there is a high screeching noise. Is this normal? Does not happen with hot water.
Old 12-12-05, 06:11 PM
D
Clothes washer
Take cold water hose off washer & check the screen on inlet valve for debri.
Old 12-19-05, 11:50 AM
R
Repoman75
Took the hose off the washer - no blockage.
Any other ideas? I have extremely strong water pressure. Could it just be that the hose can't handle it and makes that noise?
Old 12-19-05, 02:17 PM
D
That could very well be the problem. Not sure what you can do to restrict the pressure other than close the water valve slowly as its filling to see if noise goes away as you reduce the water
