Whirlpool Washer - won't spin or agitate...
Old 12-18-05, 06:47 AM
C
Now it just makes noise...
It will fill up.
A couple days ago it would work all the way to spin/rinse - then just sit there full of water. Had to manually take it to spin/rinse.But now - just noise after fill-up...
Help!
Old 12-18-05, 08:45 AM
D
Whirlpool washer
If it will pump the water out but won't spin or agitate, the coupler between the motor & tranny is bad. To get at this you have to take the whole shell off the washer. Remove the screw on each side of control panel & tilt panel back over the washer. Remove the 2 clips on top of washer & pull plug for the lid switch. Tilt the whole shell towards you & lift off. You now can see the pump & motor towards front of machine. Remove the 2 clips on pump & pull off. Remove the 2 screws on motor clips & take clips off. Un-plug motor & remove. You will see half of the coupler on motor shaft & the other half on tranny. There are 3 ears on each half. Either the ears broke off or the rubber bushing that goes between them is rounded out. Coupler part # is 285852.
Old 12-18-05, 06:12 PM
C
Dave - for the $12 plus shipping - it's worth a blind try!
Thanks.
The unit is only 6 years old - but gets put throught it's paces. I have never done anything like this - is there anything I should be aware of before I start?
cb
Old 12-18-05, 06:40 PM
D
Whirlpool washer
Should be pretty easy if you follow my instructions on getting to the coupler.
Don't make it a blind try. Get to the coupler & make sure its broke before you order a new one. Could be another problem but I'm betting on the coupler. A common problem on those washers. Dave
Old 12-19-05, 05:29 AM
C
we'll do, thanks.
Old 12-20-05, 03:42 PM
C
Got the body off...
I'm in deep now...
Old 12-20-05, 04:39 PM
C
Thumbs up
Dave - you are the king of all appliances!
One of the peices is broken into 3 peices. We are absolutely thrilled (well, for having to fix our washer).
My wife even said that turns her on when I save money
Anyway - I took digi pics so I could put the thing back together the way it came apart.
Thank you very much. I thank you, my wife thanks you, our marriage thanks you.
Happy Holidays!
I'll follow up with how it turns out.
cb
Old 12-20-05, 06:40 PM
D
Wink Whirlpool Washer
Glad to help. Just be carefull..... Those washer shells won't take much much weight when she thanks you for saving money! Happy holidays. Dave
Old 12-21-05, 01:51 PM
C
Kids - if the washers's a rocking - don't come a knockin!
Happy Holidays.
