Ge Stove Burner and Foil "pop"
Old 01-02-06, 09:58 AM
livexcellence
Red face Ge Stove Burner and Foil "pop"
Good Day,
We got a small piece of foil stuck in with the large top burner connector. Insead of it arcing which i had happen a couple of years ago this time it just popped.
The burner still turns on but has not temp control. Just high and off. What do i need to replace? the Fuse or thermostat or both?
Thanks
Dave
Old 01-02-06, 01:42 PM
GE Stove
Do you mean a piece of foil got into the recepticle where the burner plugs into? If so, you should replace the recepticle & try that first. I have a feeling though that the foil shorted out the contacts in your burner switch & fried it.
Thats why you only have the high setting or off. Dave
Old 01-02-06, 01:58 PM
livexcellence
re burner
yes exactly the foil made contact in the element recepticle. so just replace that unit then, thanks for your help on this.
Dave
Old 01-02-06, 02:07 PM
GE Stove
Replace the burner recepticle & the control switch. Both are bad. Dave
