Maytag washer making noise on spin cycle
Received 0 Votes
During the spin cycle this thing sounds like a diesel train coming. It starts low and gets significantly louder as rpms increase. The machine is 2 years old. What's wrong with it and do you think it's worth a repair (replacement is $500). It's a top loader.
You MAY have worn damper pads. The bearing assembly rides on these pads and the noise is caused by worn pads. Good luck.
Maytag makes a few different models so the numbers would be a big help.
Received 0 Votes
Ok, I have a Maytag A412, S4 that just started to rumble on spin. The damper pads seemed to be the culprit and I bought a replacement set. Trouble is, the existing pads seem to be a REAL PAIN to get off!! These things are almost merged with the base. So, any secrets to getting the old pads off?? I'm almost thinking I need to totally disassemble the washer - the replace instructions are simply 'scape off pads', yeah right!!! I'd sure the guy who wrote these instructions never did it - LOL! Please, any help is appreciated!
Any advice?
Any advice?
Lately have been installing tub seal/bearing kit on the old and new maytags... seal fails and water get into the upper bearing... every one that I came across with the roaring spin sound that was the problem...
