kenmore oven won't turn on
Old 04-10-06, 04:06 PM
Angry kenmore oven won't turn on
Hi,
I have a Kenmore double 27 inch oven that won't work..Yesterday it worked fine. The oven light & clock work and the clear/off button beeps when touched. The model # is 911-48489890. The silly thing worked yesterday and never showed an error message.
Thanks
Old 06-22-06, 04:05 PM
C
Kenmore Oven won't work
I am having the same problem with a model 790.92889301. Did you ever find out what was wrong with yours? Cooktop works, lights and buttons work, just no heat in the oven.
Old 06-25-06, 11:39 AM
rfhughes
same problem
Hello sorry I am not replying with a solution. I have the double 27 # 911.4848590. No error codes. Clock works/ start-stop beeps but cannot get it to work, If I hear or get a posting to my problem I will forward it on.
Old 06-26-06, 04:30 PM
rfhughes
Follow up
I had received this psoting at another site regarding my Kenmore double wall oven not working. I had told you I would get back to you in I got a reply. Good luck let me know how you make out as will I.
Open the control panel and make sure the ERC is getting 120vac at its power terminals. If it is, then it's toast. Come git you one: http://www.repairclinic.com/referral.asp?R=154&N=911145
