Maytag toplaoding washer Model LA506
Old 05-28-06, 06:56 AM
Washer set upon regular cycle completed cycle until spin. At this time it stays at that spot. I can maually reset the timer forward to spin, although there is no rinse.
Please advise me if the timer requires replacing?
Old 05-28-06, 04:30 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
Are you saying it will wash ok untill the end of the wash cycle when its supposed to drain and spin... or it wont refill for the rinse cycle... 1st part could be lid switch 2nd part cold water valve clogged or bad
Old 06-05-06, 04:29 AM
Thumbs up
I found the problem, somehow the hot water tap was turned off, therefore stopping the rinse/spin cycle from starting. All is ok now.
