Fridge only crushing ice (no cubes)
Received 0 Votes
I have a two door Frigidaire. Regardless of whether I push the 'Cube' or 'Crush' button on the freezer door, I always get crushed ice. The buttons light up properly when I push them, I just don't ge t the crushed ice...
Is it the door? The ice maker?
Thanks for your help,
Eric
Eric
have you pulled your ice bin out lately ? On mine there is a rod that runs along the bottom of the ice bin and the end sticks into a hole in the back of the freezer. Iside that hole is a lever that either pushes the lever up or down for cubes or crushed. The lever will sometimes stick and I have to push it down and then push the bin back in.
Received 0 Votes
Not sure what you mean
Mattison, thanks for your quick reply. In your reply you write,"The lever will sometimes stick and I have to push it down and then push the bin back in."
I pulled out the bin, and I do have the 'stick'. I did find a lever that is u-shaped. I pulled it down, but it doesn't stay down. I then put the bin back in, but it didn't solve the problem.
Any thing you see that I might be doing wrong or that I might need more clarification on?
Thanks
Thanks
I think I actually have to hold it in position until the rod is in place.
I'm not at home right now to tell what position it's supposed to be. I will be there in about an hour. If you don't have it going by then I'll check mine.
Received 0 Votes
Funny you say that
Right after writing my response, I did exactly what you just wrote. I knelt down under the ice box and held the lever down while I inserted the stick. The good news is that now I am getting cubes. The bad news is that I no longer get the crushed ice to work. I MUCH perfer the cubes to the crushed ice, so that is good.
Any thoughts on why I don't get crushed ice anymore? Perhaps the lever no longer works...
Again, regardless I am happy I get the cubes. Thanks for your help!
Received 0 Votes
Thanks
Yes, I put it in the square lever. The 'stick' under the icebox doesn't seem to turn (I assume that is what it usually does) when I choose crush, but again I don't really mind. I use cubes 99% of the time and I now longer have to open and shut the freezer all the time my electric bill and the electric company thank you!
