Refrigerator Gets Too Cold
Old 09-09-06, 07:17 AM
W
About a month ago, my refridgerator started to get too cold. I've adjusted the temperature range, but seems to have no effect. Does a refriderator have a thermostat like other things that have to adjust temperature? If there is a thermostat, should I assume this is the problem?
Thanks
Old 09-09-06, 06:36 PM
D
Too cold
The dial you turned down in the fresh food section is the thermostat. If you have it set at its lowest setting & your fridge still is too cold, chances are it needs replaced. Dave
Old 09-10-06, 06:06 AM
W
Thanks Dave.
William
