My GE washer does not drain
Received 0 Votes
Hi, my GE Profile washer's model number is WPSQ4160T2WW. It takes in water, agitates and spins but it would not drain water. The water pump does not turn. It looks like the culprit. Is there any way I can test the pump motor to be sure it is the culprit?
Received 0 Votes
the easy thing to do is remove the hoses from the pump and see if you can turn the impeller with a screwdriver, if not it is bad. If you have a multi meter you can use it to check the circuit the pump needs 100v minimum to work.
