Whirlpool washer doesn't go into 'high spin' mode
The Whirlpool washer LSQ9544KT0 doesn't switch into 'High Spin' mode and the laundry remains soaking wet. Otherwise it works fine. Doesn't look like the timer. I can engage the safety switch under the lid and turn the tub manually at the time when the washer should go into this mode. the tub will try to spin, but as if something slows it down it will stop again. It doesn't depend on the load, the empty tub does the same thing.
What might the problem be?
Thank you!!!
Thank you!!!
Not the pro here, but since there's been no post here's some stuff I would look into from this site:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
"The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
>>>Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
* If it's spinning when you lift the lid, the coupler is fine.
* If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
>>>Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
>>>Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
>>>Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve. "
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
>>>Motor coupler
>>>Spin cycle
>>>Siphoning
>>>Water-inlet valve
