drain tube
drain tube
Can anyone tell me where to locate the drain tube on my Fridgidaire Model FRT21LRCW. It may be clogged as I am getting quite a bit of water on the bottom of the fridge under the crispers.
Take the crisper drawers out and look near the back. At the lowest place there should be a hole going down. Take a bread tie or garbage bag tie or pipe cleaner and run it in the hole to pull out or push through the blockage. It ends at a pan on top of the compressor under the fridge. Remove the front lowest grate looking thing to see under there. The pan may need cleaned also. Good luck.
