kenmore freezer not freezing
Old 05-20-07, 11:41 AM
D
I have looked on forum for answers. Got some answers that were close but wanted to run this by ya'll.
I have Kenmore 19 upright freezer.
Model # 253.9209383
Manual defrost
Problem: not freezing
power is on and light is on at the bottom
will get semi cold when i plug it in---small amount of frost inside on shelves and coils
Gets hot after about an hour or so. Does not recover or get cold again until unplugged --then plugged back in.
The compressor is hot to touch.
I have almost exact unit sitting next to it.
I can hear it running and feel vibration of compressor when touching.
I cant hear the unit in question and there is almost no vibration of compressor. I can feel slight hum when first plugged in, but then no vibration after short time.
Have tried different cooling settings. Dial goes from 1-7. Have it set at 3 1/2 now.
Do not hear suction when door opened and closed.--Can hear on other unit.
Units sit in my garage. A bit cooler than outside temps since I have a cooling vents in the garage.
Was fixin to have hauled off. Looking for last ditch suggestion to get running properly.
Thanks
Old 05-21-07, 09:26 AM
D
fixed
Something I should have checked first. It was the overload and relay switches.
Thanks
