Need help removing washer front
Old 06-10-07, 09:39 AM
B
Have a GE top load washer and the spin and agitation quit. It does pump water out tho. I need to see if the belt is shot but can't figure out how to get at it. Does the front or top come off or is this one I have to remove the rear panel?? Thanks for any help!!
Old 06-11-07, 03:40 PM
D
GE washer
Using a putty knife or thin screwdriver, push in on the tabs located on the front top of front panel a few inches in from the ends. You should be able to pull top towards you & lift front panel off. I never had to replace the belt on the newer GE washers. They are alot heavier duty than the older style. I suspect the clutch. Be sitting when you look up the price. The pump is electric now & sits in the front right of machine. Dave
