Whirlpool washing machine - won't fill with water
Received 0 Votes
I have a 10 year old washing machine. I am trying to narrow down what the problem is. The machine will not fill with water and the agitator just spins.
My hot and cold water hoses are pumping out water when disconnected from the machine. So I know my hoses are working properly. I tried replacing the hot and cold water inlet valve. I was pretty sure that was the problem and am getting the same results as before.
Has anyone else had this problem? Any tips you can give me on what else to try would be helpful.
Thanks
Candyman
Thanks
Candyman
Received 0 Votes
Here's a little more basic troubleshooting info for you that might help you out some:
http://www.repairclinic.com/0088_11_1.asp#Level1_11
http://www.applianceaid.com/faq-washers.html (Page down to where it shows "My washer will not fill w/cold water (or hot water)".
Not the pro around here, but it might give you some idea as someone else may chime in here.
BTW: Welcome to the DoItYourself.com forums
