Refrigerator temps?
Old 07-03-07, 06:51 AM
Refrigerator temps?
Just bought a used ge top freezer/fridge for the shop.temps running 40 in fridge and 10 in freezer at maximum settings. Everything clean running quietly . Is this normal for 15 year old fridge? If not what to check ? Thanks
Old 07-03-07, 12:45 PM
D
Received 2 Upvotes on 2 Posts
From this site:
http://www.repairclinic.com/0088_4_4.asp#Level1_5
fridge should be 36-42 degrees
freezer 0-8 degrees
Check back as the pros will chime in
Old 07-09-07, 05:30 AM
Question Refrigerator temps
After some adjustments on temp control the freezer is 0-5 Degrees but still cannot get fridge temps below 40 -45.Surely someone knows some possible causes. Thanks
Old 07-09-07, 02:46 PM
E
Received 1 Upvote on 1 Post
Is the fan at the back of the freezer blowing, and can you feel that cold air being blown down into the upper rear of the refrigerator compartment? Post back so we can move on from here.
Old 07-10-07, 06:30 PM
ecman51 yes to both questions.
Old 07-11-07, 03:29 PM
E
At a 10 degree freezer temp, your refrigerator temp may be normal. To lower the freezer and refrigerator temp at the same time you would set the refrigerator setting to a higher number. If you have no numbers, then you would turn the REFRIGERATOR control dial to a colder setting. The FREEZER control is really only a baffle. But you could also try turning that to the coldest setting and see what happens. By increasing the flow to the freezer causes less cold air to go to the refrigerator section, which in turn makes the refrigerator run longer to reach 'set point', which then can lower the temp.
Old 07-12-07, 04:06 AM
Thanks I'll try that.
Old 07-12-07, 08:02 AM
Pendragon's Avatar
You say this is for your shop, which implies it is outside or in otherwise unconditioned airspace.
It's not going to get as cold in 100 degree air as it would inside in 75 degree air.
Especially considering it's age.
Have you clean the coils lately?
Old 07-12-07, 09:45 AM
B
Have you checked the seal around the doors? If not, take a dollar bill and go all around the door/doors with the door shut like it normally would be. You should feel a slight tug on the dollar if the doors are sealing. Those temps sound pretty good.
P.S. Been a while since I have been here. Have different provider now and had to re-register. Plus my sn is a little different.
