smooth top electric range/oven question
Old 07-05-07, 07:57 AM
Question smooth top electric range/oven question
Whats the name of the part that heats the oven
the coil like glows when turned on
anyways that part burned out and i want to replace it my self
i have a kenmoore range don't know the serial # off hand but it seems like a simple fix it looks like 2 screws holds that piece i just need to know the name of that part
THANKS
Old 07-05-07, 07:10 PM
The element at the bottom is called the "Bake Element". The element at the top is the "Broil Element". Is it visibly burnt out or is it just not heating? There are several things that could cause an oven to not heat.
You should disconnect power to the unit before working on it.
