Jenn-Air Convection Issue
I have just recently moved into a house with a Jenn-Air SVD 48600. The convection fan never turns on. I only have the user guide. Any ideas on quick things to check before I call for service.
Thanks
Thanks
Does this unit have a choice where you can set it for convection or not? If so, some switching mechanism would be at play.
Are you experienced at all with simply tracing wires, and volt and ohms testing wires, terminals and motors? Can you at all read a wiring schematic to some degree if you found it in your unit, say inside a console or behind it?
I have no experience, personally with such a machine, but you can bet I'd have a go at it, checking the stuff I just mentioned. A schematic would make it clear what other devices would 'trip' the convention feature to come on.
