Whirlpool Dishwasher - food grinder clogged
Old 11-16-07, 08:09 AM
I have a Whirlpool GU1200XTLQ0 dishwasher. It has an internal "food grinder" that chops up food particles and then filters them through a screen before the water gets to the pump. When this screen gets clogged, the pump doesn't get much water so the dishwasher doesn't wash - no output pump pressure. When I clean the screen, the problem is completely resolved, but lately that solution only seems to last for 5-10 wash cycles and I have to clean the screen again. It doesn't appear that the little spinner/chopper is properly engaging to chop the food - the screen is just clogged with food particles.
None of the small parts seem worn, damaged, or broken, but it is as if the spinner isn't spinning so maybe I've reassembled something incorrectly.
Ideas or suggestions would be appreciated.
Old 11-16-07, 10:54 AM
Update - problem solved
I replaced the "chopper assembly" which is the screen, the chopper blade, and the plastic shaft (less than $20). Comparing the new part with the old made the problem obvious - and the dishwasher now runs great.
