GE Washing machine WVSR1060A1WW
Thanks in advance.
Aaron aka "Sore forehead in Ohio"
Look for the water level control in the console. Follow the hose back down to the tub [you'll have to take off the front panel] and see if the hose is obstructed/occluded or maybe has some water in it. If that's ok, you may have to replace the water level control. Let the machine fill and go to the point where it stops, then try blowing into the hose to see if the WLC makes to the full position. You'll need to have the lid closed or the lid switch bypassed. I'm not sure why the belt is shredding unless maybe it's an older machine and the belt is just worn. Let us know how you make out.
http://www.appliancepartspros.com/pa...odel_id=230734
