Frigidaire range not heating
I have a Frigidaire electric range model#FEFL77ABE. Last year while cooking Thanksgving dinner the breaker tripped. Reset breaker and no problems. My wife was cooking last night when the breaker tripped again. She reset the breaker and was able to finish cooking in the oven but none of the top elements would work. I got to chekcing it out this morning and no top elements or the oven elements will work. There is no trouble codes on the display, the display works fine and the red indicator light comes on when you turn on an element or the oven. Anybody got any ideas?
Thanks,
Steve
Thanks,
Steve
Nevermind! I found the problem. I checked each hot leg and one had no voltage on one and the other was 119v. Went outside to the breaker and one side was 119v and the other was 0. That's a lot better than buying a new E.O.C..
It is great that you found your problem and did not have to replace anything.
If you ever need anything here is a good place to get your Frigidaire Parts.
Thanks,
Steve
Thanks,
Steve
what gauge is the wiring from the stove? is it 8 or 10 gauge ?
