Electric Dryer (Kenmore Elite) won't heat, lots of testing
Received 0 Votes
Hi All,
I hope someone has some sage advice, 'cause I'm out of ideas.
We have a 5 year old Kenmore Elite dryer. A month or so ago it stopped heating. I found a series of excellent videos online that walked me through a ton of tests. I also found the service manual (inside the dryer, under the timer) and ran all the tests under the "Dryer Won't Heat" section. Here's what I did:
* checked continuity on the heating element (ohm meter check: continuity and no shorting against housing)
* checked continuity on both the thermal cut-off and high-temp. cut-off (ohm meter check: continuity verified)
* checked the thermostat (continuity)
* checked the thermistor (ran automated tests from the manual, checked fine)
* checked the centrifugal switch on the motor (continuity in the closed position (had to take off the front of the dryer for this one: a pain!)
* checked all of the manual recommended continuity checks on the timer (all fine)
* checked voltages at the inputs to the dryer (all fine: 120 with neutral and 240 both hot (outside connectors))
* pulled the heating element and hardwired it to a plug (it heated up)
Any other ideas? I'm stuck, stuck, stuck.
Thanks!
ken
Thanks!
ken
Received 0 Votes
Kenmore dryer
Yep. That about covers it all except maybe a broken wire somewhere. Highly unlikely though. I ran into a similar problem & was pulling my hair out untill I turned the timer knob a few times while it was running & got it to send power to element in certain positions at different times. Turns out a contact in timer was bad. Might be giving you a false ohm reading while off. Worth a shot.
Received 0 Votes
Thanks. It was certainly worth a shot. Unfortunately, still no go. I tried about every timer combination I could think of and no heat.
I think I have to call in the cavalry (a Sears repair tech.)
Got a model # you might have a bad heater relay. in control panel there are 2 relays center relay has 4 wires to it, to large and 2 small wires going to it. yurn machine on in a heat position, use volt meter across the 2 large wires and if reading 220 relay is bad. if 0 relay OK, need model # to tell if you have that drier.
