Kenmore Series 80 problem with filling for rinse cycle
the model # is 110 92281100. It fills just fine for the wash cycle, empties properly but when it reaches the rinse cycle, at the point where it is supposed to fill with water, it is 'bucking' and there is a loud 'clicking' as if it is trying to get water through the pipes but not quite succeeding.
My husband wants to just buy a new washer, but perhaps someone here will have a fix for this we can handle on our own.
Thanks for any info you can provide
is that something relatively easy to repair, or should we call in a repair person? Is it expensive i.e. is it even worth replacing either of those parts or should we just buy a new washer?
Thanks
Thanks
Rinse cycle work on cold water only, make sure you are getting cold water coming in from the wall ( cold not shut off) usually water fill valve bad.
