Kenmore 417 dryer won't start
I have a 3 year old Kenmore 417 dryer. We have power to it, all options are lit up but when I press start, it won't start. It was running as recently as this morning. I have unplugged it, 'locked' and 'unlocked', tried different settings. The time appears, the lights are lit - but won't start. The beep is one beep when I press the 'start' button, not 3 with an error message.
Any thoughts? Thanks,
Ck thermo limiter (fuse) take top off right rear conner behind drum, small round fuse with 2 wires, should have circuit through it. unplug machine before doing this. can replace without taking drum out but is difficult
I have the same Kenmore dryer (417.84082500) and the same thing happened to me this weekend. All the lights come on as they should when I hit Start, but when I hit Start again to actually start it, it won't start. No error codes are displayed. My husband went ahead and ordered a thermal limiter online (sears part #134120900). It'll be a week before we get the part. I was wondering if changing the thermal limiter solved your problem.
More information: We put the dryer into test mode and ran all of the tests -- all of them seem to work as described in the service manual. In fact, I wound up drying 2 loads of laundry using the test mode because that was the only way I can get the dryer to work at all. Our dryer was purchased in March 2005 - 8 years old.
Any one else with ideas of what else to try? Thanks in advance!
I don't think it would run in test mode if the thremal limiter was bad. Not sure if test mode bypasses it. Put it in and see if it works. It you take the drum out to replace lube the plastic bearing in back.
Thanks for the quick response, pugsl. We'll give the thermo limiter a try when the part arrives -- probably next week. My husband is hoping he can replace it without taking the drum out.
In the meantime, will I damage the dryer any more by using the test mode to dry my clothes? I have no control over the settings in test mode, so I'll need to be extra careful and not leave stuff in the dryer for too long.
I doubt you'd hurt the dryer but if you are indeed running it without the benefit of a required thermal limiter you need to be observant of an over heating condition.
Also.....a thermal safety sensor usually fails due to high exhaust temperatures which are caused by a restriction in the vent line. With an electric dryer it is imperative that the vent line be clean and lint free.
While you have the dryer apart for service.....vacuum it out. Remove vent line from back and vacuum inside the back of dryer especially the blower wheel. Make sure line to outside is thoroughly cleaned.
