Ge Washer won't stop filling- overflows
Old 04-22-08, 12:11 PM
Ge Washer Model: whdsr209Daww
Our washer will not stop filling, it over flows. This did not happen all at once, it over flowed than next time filled ok, than overflowed than next time filled ok etc. It did this for about a week, now it overflows all the time.
Old 04-22-08, 05:54 PM
pugsl's Avatar
Received 25 Votes on 24 Posts
dose it fill with the washer off, if it dose than you need a fill valve. If it only overfills when turned on could be 1 of 2 problems, first is pressure switch (water level) or the fill valve is sticking
Old 04-22-08, 09:27 PM
Unclediezel's Avatar
The next time it overfills......Pull the plug out of the wall.
If it keeps filling, even with the machine unplugged, The fill valve is stuck and needs replacement. If the water stops filling with the machine unplugged, Suspect water level/ pressure sensor, Or a damaged hose between the "Air Bell" and Pressure transducer.The damaged hose becomes more likely if the machine has been recently "Dissasembled " or serviced.
