Kenmore Dyer Not Starting
Old 04-23-08, 12:27 AM
I believe the model# is 66812692.
When pressing the "start" button, heat comes on and clicking sound is heard from the timer, but the dryer doesn't start.
Just an FYI: This is my first time ever working on a home appliance, so I have no clue where to start the trouble-shooting process. Please be kind
All help would be greatly appreciated.
Old 04-23-08, 06:14 PM
Sure your motor is not spinning with the belt disconnected? Have you tried to open a bottom access panel and have a look?
Old 04-23-08, 07:42 PM
I am having about the same problem.
I think it wants to starts, but doesn't. u just hear the humming.
It happened before, but a year or 2 ago, but if I waited a few hours it would work again. But not this time.
I never open one before. Should i be concern of electric discharge?
My dryer is probably quite old. It was there when I granddad was still at home, so over 20yrs. it is an Inglis or Inqlis Citation.
Old 04-24-08, 04:49 PM
It doesn't seem to have a bottom access panel. It looks like the entire front piece would need to be removed.
Old 04-24-08, 05:15 PM
pugsl's Avatar
Received 24 Votes on 23 Posts
NRJ IF THE HUMMING NIOISE IS COMING FROM THE LOWER AREA YOU WILL NEED A MOTOR.
the not starting dose the drum turn fairly easy by hand? if so the belt might be broke, door switch bad may also cause problem
Old 04-24-08, 05:20 PM
The drum does not turn easily, there is resistance. Is there a way to test the door switch?
Old 04-24-08, 05:39 PM
it turns but not that easy and i can only turn it in one direction.
Old 04-24-08, 07:06 PM
Not to sound rude, could you start your own thread? I just don't want to read through posts to find a response that is meant for me.
Old 04-24-08, 08:04 PM
since it is basicly the same problem, why start a new thread?
Old 04-25-08, 12:57 PM
I believe I found the problem.
Bypassed the thermal fuse and the dryer started. Will be buying a new one within the next hour.
Old 04-27-08, 02:48 PM
If you are still around, keep us posted. The thermal fuse should not allow the dryer to heat, turn - nothing. But you said yours got hot without turning the drum. That does not sound like thermal fuse. You may have a coincidence occuring if you bypassed it and it now works. It probably would have worked if you let it (thermal fuse) remain plugged in.
