GE Model JTP15 Built-In Oven F-2 Error Message
Old 04-23-08, 04:51 PM
My GE Oven works fine in all modes except self cleaning. After about 2 hours of self cleaning, the F2 error message comes on. I cannot reset the error. The only thing that I can do is turn off the circuit breaker until the oven has cooled down. The oven works fine after I turn the circuit breaker back on (except self cleaning)
Old 05-05-08, 06:15 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
cajim
GE-Hotpoint-RCA: Oven Fault Codes:
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
