GE Electric Model DDE7900RAL - Heat Set
Old 05-03-08, 11:27 AM
Question GE Electric Model DDE7900RAL - Heat Set
This GE model has a push button panel to designate between High - Medium - Low - No Heat and a Start button. Current problem is no heat on the MEDIUM setting only. High and Low work just fine. While I am mostly inclined to then zero in on the switch as my problem, all of the articles I've been able to read address no heat at all and thus point to fuses, thermostats and/or heating elements. So question is: anyone else had a similar issue, what is best method to test prior to purchasing parts and what fixed yours?
Old 05-03-08, 03:12 PM
pugsl's Avatar
Received 22 Votes on 21 Posts
Unplug dryer should have contunity between contacts when you push each button, temp switch is a single switch, Should be wiring diagram under consul
