Washing Machine overflows
Old 05-12-08, 12:15 PM
Kenmore washing machine overflows. It would fill up according to the water settings. Then a few seconds later it start filling up again causing it to overflows. Any suggestions!!
Old 05-12-08, 03:46 PM
pugsl's Avatar
Received 19 Votes on 18 Posts
The water shuts off than starts again? Pressure switch maybe leaking air or the plastic hose that goes to it may have a pin hole in it. Pressure switch located under consul has clear plastic hose to it
Old 05-13-08, 10:50 AM
Pressure switch
Pressure switch? Is that the same as Water Level Switch?
Old 05-13-08, 04:13 PM
pugsl's Avatar
yes it's called pressure switch as it works on air pressure
