Maytag Neptune 9700AWW
We cannot get the front door off to replace the drum boot. Can anyone give us specific directions on how to remove the front door?
thanks
thanks
need rest of model # to see picture to help Should start with a m # is on top of control panel in back.
If I remember right remove screws in door area and then panel will tilt out and lifted off. 2 screws on each side holding clips that hold top down. Lean top back and than remove screws holding the next panel on. You also have to loosen door latch assy on the top. Think you should be able to see what to do from there. I always have to have 2 men to reinstall spring that holds on boot to tub. Don't have strength in hands to do it any more.
