Washing Machine Problems with filling
Could someone please help me out as to why my daughter's washing machine will fill and run through the wash cycle but it will not fill when it gets to the rinse cycle. You can hear the timer running, but it will not fill??
Thanks for any suggestions we could try.
Check to see if the cold water is turned on. Rinse are with cold water, If cold on then check to see if the screen in the valve inlet is clear, Take off hose and use a small screw driver to remove screen. If screen clear than you need a water valve. Give make and model # and will tell how to replace.
also check
With the washer lid closed see if you have power to the fill valve during the rinse fill cycle. Then if the fill hose screens are clean and the hoses aren't reversed and you have power to the fill valve. Your the proud owner of a new fill valve
