Burnt wire on dryer
Old 07-15-08, 05:39 AM
L
Burnt wire on dryer
Hi about 2 or 3 months ago I replaced the heating elements on my dryer then last night I blew 2 fuses .took the dryer appart and found a burnt wire .Question could when I put this all back together something was rubbing this whole time or another issue ?
Old 07-15-08, 09:32 AM
B
Wher was the burned wire...? Usually a burnt wire is discernable from a rubbed wire, and burnt wire means high resistance typically at a connection. Maybe you had a bad contact at a spade connector. Tell us where the wire was.. If it was at the heater element that is pretty common and most new heaters come with a couple of pieces of wire just for that event..
Old 07-15-08, 09:45 AM
L
It was in the middle of a wire burnt the insulation reight of in a smak area . It is a wire I think for one of the sensors that tells the dryer to shut off close are dry .
Old 07-15-08, 02:18 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Please give model # so we can see what machine you have.
