Kenmore Front Loader Not Draining
Old 07-18-08, 06:49 PM
D
Mod. 417.29052990, SN XC91667107
Not draining and a huge mess. What can I do to fix short of calling Sears? Thanks for any suggestions...
Old 07-18-08, 07:51 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Take off lower panel and water pump is there (RF) Take off hose from tub ( 5 gallons of water in there) and see if you can find anything in the pump,
Old 07-18-08, 09:50 PM
D
Thanks much for the prompt reply. I'll give it a try tomorrow and post back...
Old 07-19-08, 10:20 AM
D
Pugs; I did as you suggested and you saved me some money. I found a hair barret (sp) stuck in the impeller of the pump. Simply pulled it out and the impeller spun freely. Also found $2.92 in corroded coins in the rubber boot at the bottom of the drain. Amazes me that kind of stuff can get through the drum and down in the pump area...Thanks much for your help...machine works like always now...Dan Wilson
