Whirlpool Stove/Oven
I have a whirlpool Stove/oven Model RF364PSBN. We had a power failure today and the oven stopped working. The stove works fine but the control panel is not working. When the power came back on PF never showed up on the display. Is there a fuse that may need to be reset? Or is the control panel bad.
control panel
maybe the control panel. but try to turn off the breaker for the stove for 30 seconds and turn it back on go to stove press start for 30 sec. and may be that re-set it good luck. hdez.....
I just flipped the breaker off for 1 minute came back up to kitchen and its working. Thank you so much so the advise you just saved me $1000 for a new stove.
